Heyo, this weekend I installed new tie rod assemblies and H&R springs. Along with new spring pads and lemfeorkjqder upper bearings. Everything's great, except now when I turn either direction, the car pulls harder the more I turn it. As in it's fine going straight, but if I let go of the wheel the car may veer off a bit, but instead of going off slowly at a constant rate, the rack speeds up and turns very sharply.
Another way of putting it is my power steering pump is going out and only works at low pressure, which is kinda nice because it's halfway in between power steering and no power steering, but once I turn the wheel in either direction past about 45 degrees, the front wheels turn as if it had fully functioning power steering. As in really fast. Like they want to turn the more you turn them. The fluid level is full.
I've looked it up a bit and most people say they have this problem after lowering their car. But sometimes it shows up at random. So what can you do to fix it? Besides learn to deal with it. Is it because of my power steering? This seems like kind of a safety thing so I would like it to feel normal again. Is there anything I should double check? I used my old tie rods to get an approximate alignment. Any way I can DIY a proper alignment without paying for one? I need to get new tires but I want to get new wheels first and would like to save money by getting an alignment with the tires but I'm not sure when the wheels are going to happen, so if there's something cheap and good enough for now, that'd be the best. Thanks!
Car is a 6/1987 325ic
