Steering Woes Again!
  • freeride53
    • 11972
    My 91 318i recently (again) started experiencing issues with steering.
    When turning the wheel I experience resistance, sometimes more than other times...
    This car has P/S, and the steering wheel is starting to feel as if is is "getting stuck"...and tougher to turn at certain points.
    I had these issues over a year ago, after I drove through a puddle of water.
    Since then, I have gotten:
    -new e30 m3 steering rack
    -new inner and outer tie-rods
    -new control arm/CABS
    -professional allignment
    -p/s fluid flush
    I am brain-boggled. Why does my steering start feeling "rough" at times?
    1983 Peugeot 505 STI
    1992 Volvo 240 Wagon
  • LJ851
    • 7919
    Maybe your pump is fading out.
    How are your u joints in the steering column?
    Lorin
    The M30 is God's engine.
    • estoguy
      • May 2013
      • 1087
      +1 on checking the u-joints in the lower steering column.
      My steering was getting bad, and it was the lower u-joint in my case that was causing the problem.
      Estoguy
      • freeride53
        • 11972
        I think my u-joints have seen better days.
        But we have indeed pinpointed the p/s pump.
        Good call Lorin!
        Now I've found a nice $80 pump that's used, but wanted to get some perspective - would you guys buy new or used?
        • LateFan
          • May 2013
          • 4436
          I'm like you in that the used part fits my budget. But a part of me says, The first one lasted 25 years, I should probably just put a new one on.
          These guys will know more about used ones though.
          • turbo55
            • Jul 2014
            • 223
            If is it a u-joint problem, you could at least tide it over by spraying it liberally with white lithium grease. When my steering was binding up a bit and that loosened it right up!
            • freeride53
              • 11972
              Replaced the power steering pump & belt, but the steering still feels sorta weird.
              I drove the car from San Diego to L.A. to San Francisco yesterday, but it's still sorta bothering me.
              Guess it's time to look into the u-joints! :(
