Hey guys,
Long time reader, first time writer. I picked up a 92 Vert M42 a few weeks ago. Body, top and interior are in great shape but mechanically it needed lots...almost everything. So after refreshing the engine oil seals, cooling system, sorting out some wiring, doing a z3 rack swap, new exhaust and a bunch of other misc. things, it was time to put the new suspension on and take it for a spin. I ordered a set of H&R Race and because budget is running up against the limit I set myself before buying the car, I chose to go cheap on the shocks. I figured Koni STR.T were new and would be a good replacement for the KYB that most people that cheap out on the billies or Koni adjustables, get.(mistake number 1)
Right off the bat, the Koni Orange Str.t struts didnt come with retaining sleves, you know, the collars that hold the inserts in the housing. Luckily my old ones were ok, so I reused them...so far not impressed. They also didnt fit in the factory upper mounts. The nuts are too large and you can't tighten them...even with special tool (which I have.) So after some research, i found out Boge had a larger diamater (32mm) upper mount (thanks R3v) so I order a set. Annoying delay, but nothing major.
THE BIG PROBLEM: Rear springs and shocks go in with new mounts like a dream. Fronts go on with the new Boge mount, new control arms and bushings, new sway bar links, set the car on the ground and take it for a drive. Right out of the garage, any minor suspension movement causes a loud clunk and bounce. WTF?? the struts are bottoming out!! After rechecking that all is tight, it does appear that these struts are giving me about 1/2" of travel and then they bottom out. In all of my years of working on cars, I have never seen this before. Even cheap struts will collapse completely- granted they will fail prematurely from working at the bottom of their range, but they don't bottom out with 4-5 inches of the rod still extended!
I'm at a loss. Today I will pull one back out and check the travel out of the car. For F*%&K sake! I knew I would be sacrificing longevity for cost, but I didnt expect this. Has anybody had similar experiences with any other Strut inserts?
Thanks,
-G
Thanks,
-G
