Sway bar still good?
  • ElJimo
    • Jun 2012
    • 166
    I'm refreshing all the suspension components on the front of my car, here are some pics of the sway bar. It has some pitting from rust corrosion where it's surrounded by the bushing. Is this negligible or something that needs to be replaced? I wirebrushed the rust off and am painting it with rust converter, so it shouldn't get any worse than it already is.
    Sizing fixed!
    Thank you AndrewBird!
  • AndrewBird
    The Mad Scientist
    • 11897
    It's not ideal to re-use them, but it isn't un-safe or anything. The bushing might not fit properly and the cause the bar to move around and make a bit of noise. I'd run it though until I found a replacement or went to a bigger aftermarket bar.
    And as far as picture re-sizing goes, you need to re-size them before you upload them. I use this plugin and it works great. Super easy to use.
    • ElJimo
      • Jun 2012
      • 166
      I guess for the time being I'll just reuse it as i just ordered new bushings in the original size. If it's too noisy to tolerate I'll take it off till I get a new one. Thanks.
