I'm gathering up parts for my suspension refresh and I was wondering if I need new control arm brackets and new spring pads ?
Do these parts need replacing ?
FS: Plug n Play Second Trunk Light !
My Parts for Sale Thread~
x 1984 325e 2.7i ~ CastroMotorsport Built x Daily Driven
Tags: None -
Your spring pads should be fine.
By "Control Arm Brackets" are you speaking of what are commonly called "Lolli Pops" which house the rubber bushings?
If so, they are most likely not in the best of shape, unless they've been replaced recently. The bushings can be pressed out, and replaced, without replacing the entire assembly. -
Alrigh cool.. I thought the pads were like gaskets.
Yup the lollipops lol Also are the m3 bushings an upgrade compared to the OE ones ?FS: Plug n Play Second Trunk Light !
The m3 bushings are much more solid, and add caster for better tracking.
I run them in all of my e30s with no ill effects. They do push the wheels forward a bit, so if you have crazy poke, they may rub.
My Cab is running 17x8s up front, with a 22 offset, and doesn't have a problem.Comment
Yeah I should be fine then. I'm gonna have some 15x8 +25 and maybe run some 10 or 12 mm spacers. Thanks againFS: Plug n Play Second Trunk Light !
