My powersteering problem.
  • BECKSTER
    • Jun 2015
    • 667
    Hey R3v.
    My power steering is acting up. It's sound like Godzilla taking a dump after Taco Bell, seriously.
    The reservoir is full of new ATF fluid, and the reservoir isn't leaking.
    However the Line going down from the reservoir slightly leaking at the bottom.
    Why is it making this awful noise when I turn the wheel?
    1990 Alpine 325is
    1992 Schwarz 325ic (sold)
  • glnr13
    • 1334
    you need to replace the line.
    • Czur1991
      • Jul 2015
      • 100
      Originally posted by BECKSTER
      Hey R3v.
      My power steering is acting up . It's sound like Godzilla taking a dump after Taco Bell . Seriously. ?
      "I have a vision and I won't stop"
      • BECKSTER
        • Jun 2015
        • 667
        Originally posted by Czur1991
        Yes it does , seriously .
        1990 Alpine 325is
        • ST1G
          • Oct 2012
          • 6689
          I have the answer.
          1.) Belt has fluid on it so it's slipping around the pulley when you're turning and putting extra stress on it.
          2.) Pump is failing
          3.) Belt is stretched and slipping, needs replaced
          I have both a new belt, and a good working pump if you'd like to purchase them. I can also help you install if you drive out to my house.
          • BECKSTER
            • Jun 2015
            • 667
            Originally posted by ST1G
            I have the answer.
            2.) Pump is failing
            You have solved my problems, all of them.
            1990 Alpine 325is
            • sonomabimmers
              • Dec 2015
              • 802
              I have the answer.
              2.) Pump is failing
              soory to dredge up some old shit i just found this in a search. Every time i turn my wheel left and left only it makes a power steering noise. to the right is perfect but to the left is a bit harder to steer, makes noise and my rpm's dip down while i turn it then come back up? i noticed my belt was loose some you think the solutions you described are my problem ? thank you in advance.
              i love bmws
              • BECKSTER
                • Jun 2015
                • 667
                I've had power-steering issues on both of my e30's, a new or rebuilt pump helps out a lot.
                1990 Alpine 325is
                • sonomabimmers
                  • Dec 2015
                  • 802
                  I got the problem under control unfortunately I think a new pump is still in my future thank you for answering
                  Tapatalk
                  i love bmws
