Im considering a set of 60mm F/50mm R springs for my 89 vert. Anyone have them and how do you like them?
Any feedback or reveiews on Lowtec springs?
Tags: None
I bought them couple months ago but have not install them yet. They have good reputation for offering best drop. I suggest you run them with sport shock, they might blow your stock suspension in long term. -
Have them they are good for what they are. And get shocks so you don't blow the stock ones.
Sent from my SM-N910V using TapatalkOriginally posted by ErickDude the M30 is stupid simple design. It's 6 manly men inside the block pushing up and down on the cylinder with Hercules-like force.Comment
I have the 60/50 combo for best results I recommend using drop hats I still wasn't happy with the stance before I added E90 drop hats, now its spot on. I have billy sports and the front seems to have not enough spring for the shock stiffness but not as stiff as IE3"s or H&r races good for daily the rear is firm but not to soft just enough for daily use. overall I'm good with thenFEEDBACK:
http://www.r3vlimited.com/board/showthread.php?t=316212
BMWCCA #398608
IG @yagayo38
"The Best E30's were built with two camshafts four cylinders and sixteen valves!".Comment
