Okay so ive decided to swap the bavauto springs that came with my car for some H&R sports. Upon comparison i notice that the two springs are the same height, very nearly (.2mm) the same thickness, same number of coils, and very similar spacing(<2mm diff.). So my question is what makes the spring rate different? Should i return these or will see a difference?
H&R vs. Bav auto stiffness
IE3's you wont be hitting stuff all the time unless you are totally oblivious to everything on the road. I ride on Turner's Jstock springs and I dont hit stuff.
WillRIP e30 (brilliantrot '91 325i) 11/17/06 Byebye: 8/21/07
Welcome e30 (brilliantrot '90 325is) 12/23/06
DaveCN = Old Man
My signature picture was taken by ME! Not by anyone else!
Originally posted by george gravesIf people keep quoting me in their sig, I'm going to burn this motherfucker down.Comment
I have had ie's for over a year and i only worry about my reiger lip. I never have trouble with anything else. Its low but it can be a DD.Comment
Well i put in the H&Rs and ill let you guys no sometime over the weekend. Im waiting on a part to arrive at the dealership and then ill need an alignment. I also replaced the CAs, installed M3 CABs, and replaced tie rods and sway bar links. Bilstein Sports and new strut bearing and mounts are about a year old.--WillComment
