Hi all, so I'm planning on getting sway bars for my e30. Going to run h&r races with billie sports. Seems like 22/19 is the ticket, but after looking into the benefits and drawbacks of m3 front links I have a question or two. Are people running the 22mm front bar and m3 links experiencing understeer? I read on the s14 forums a 19mm front bar with m3 links is approximately as stiff as a 24mm bar with the control arm mounted links. In theory then a 22mm bar would be overkill with m3 links.
I would like to keep the traditional control arm mounted links (no wheel jacking on tight corners due to less sway travel) and try a 25mm bar up front, as that seems to be the middle ground (between 22mm with m3 links which should be too stiff causing understeer, and 22mm with regular links which seems hardly noticeable at 2mm over stock).
Is anyone out there running 25/19 with control arm mounted links that can chime in?
