ok need some help
  • 89AlpineM3
    • 548
    ok need some help
    The front toe on my 89 M3 is too far out, everything is brand new and the tie rods are screwed all the way in and the toe on the passenger side is still pretty far out and the drivers side is pretty close but also out a little. Any ideas on what I can do????
    Arc Asylum front subframe
    new control arms
    new tie rods and ends
    new condor speed offset control arm bushings
    new hubs
    new bilstein sports
    new H&R sport springs
    new Ireland race camber plates
    new E90 drop hats
    new Ireland sway bar
  • DesertBMW
    • Aug 2011
    • 1039
    Yes. What you do is adjust the tie rod ends on both sides until you have proper toe alignment. This has to be done on alignment machine.
    • dirtythirtyboy
      • Oct 2015
      • 23
      Go to shop and get an alignment
      Sent from my HTC One_M8 using Tapatalk
      • AndrewBird
        The Mad Scientist
        • 11898
        Guys, he said the tie rod ends are screwed all the way in and he still has toe out. Something is obviously wrong.
        I'd guess you have the wrong tie rods. See if you can find a part number on them and check them on RealOEM.com.
        • YosemiteSam
          • Apr 2011
          • 1303
          This. Or maybe your strut/spindle assembly is bent. If all else fails you could always just cut a bit off the ends of the tie rods.
          • 89AlpineM3
            • 548
            Checked the end on realoem and they were correct, I know nothing is bent as everything was straight when I took the car apart for the restoration. I will trim down a bit off the end and see if the helps. Thanks
