5" rear springs
  • Sirrrrred
    • Jan 2013
    • 25
    5" rear springs
    Just bought a coilover set up from ground control. How low does 5" rear springs go. Does anyone have a pic.
  • ak-
    • 12422
    Barely tucks the rear tire if you have a late model.
    Spring rate matters though - and this is without an adjuster.
    1991 325iS turbo
    • Sirrrrred
      • Jan 2013
      • 25
      spring
      I told the guy at GC That i wanted 4" springs. He was pretty against it. he was saying 5" would get the rear dumped. could I remove the adjuster.
      • ak-
        • 12422
        It won't if you're looking to dump the car. Lots of us, including me, have been down that path.
        Is your car early or late model?
        I'm using 4" springs with adjusters from HyperCo.
        1991 325iS turbo
        • eLKuRLy
          • Oct 2007
          • 360
          I believe mine are 5" with no adjusters. 650#
          • Sirrrrred
            • Jan 2013
            • 25
            springs
            eLkurly
            That looks great. Thats the look I'm going for. how does it ride. Any bottoming out. I have a late model AK
            • ak-
              • 12422
              Ah okay. Depending on rate, you'll be able to get away with it if you're trying to really lower the car considering your late model arches like the link above.
              1991 325iS turbo
              • eLKuRLy
                • Oct 2007
                • 360
                Originally posted by Sirrrrred
                eLkurly
                I'm running the Camaro KYB Gas-A-Just shocks and the ride is firm and not harsh. Probably because riding on bumpstops. Front struts are cut 3" and using Corrado yellow sport konis with an 1" spacer.
                If you planning going low, plan on getting a skid plate too.
                • Sirrrrred
                  • Jan 2013
                  • 25
                  Awesome, thanks guys I'm gonna do the exact same thing.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    are your rear springs from GC 2.25 or 2.5 inch ID?
