24v swapped w/ e36 steering rack...
  • Brew
    • 3060
    Need to know which power steering line to use from the resevoir to the rack. The e36 line will not work, and neither will the e30 325i line.
    Thanks in advance.
    '91 318is
  • cheades
    • 632
    I used the e36 line but bent it all up to fit and bolted it to the frame rail.
    • e304me
      • Feb 2006
      • 1374
      you can just cut the metal hard line and use a differnt hose with a hose clamp on it if that will work. since it is low pressure
      • Brew
        • 3060
        Thanks for the replies.
        I just ordered up a e36 318 return line that should be in on Monday so we'll see if that fits.
        '91 318is
        • Garageaholic
          Freestyle Fabricator
          • Dec 2005
          • 5204
          How did it fit????
          Recent Rebranding!!
          E30 SM62/S62
          E30 M60 V8
          E30 M30 Big 6!
          Instagram.com/garageaholic
          Youtube.com/garageaholic
          • Brew
            • 3060
            I snipped a few inches off and it fit well.
            '91 318is
            • 1991 318is
              • Dec 2005
              • 786
              Made up lines.
              I went to a hydraulic line shop. They cut the banjo fittings off and soldered their compression fittings to them. The cost was $60 for the high pressure line. They do this everyday for construction equipment, tractors, etc.
              • Sean
                • 5793
                I bent an e36 line up to get it to fit - made sure I didn't kink it of course!
                - Sean Hayes
