Hub Adapter Stuck
  • WoozyGambit
    • Jan 2017
    • 5
    Hub Adapter Stuck
    Recently invested into a crappy chinese hub adapter in my e30. Was told by the seller to push it in by hand and then tighten as per normal as the splines were a bit sticky. I tightened it and tightened it and eventually it became too tight. It as now stuck to the point where the wheel has locked and i cant even turn my key. Any tips on how to remove this would be greatly appreciated
    Thanks
  • rcsoundn1
    • Nov 2012
    • 3361
    Which one did you buy? The wheel has a torque spec, not sure what it is. You may be looking for a steering column now. Post some pics/links
    • FireFight
      • Mar 2012
      • 1367
      I went though this as well, to pull it off i rented a autozone 3 jaw puller and used that to pop it off.
      we ended up repeating this process about 20 times, and finally it felt like how it normally feels going on and off. not saying i would recommend this, because you are liable to fuck up your splines on your steering shaft
      WTB:m60b40 in PNW
      Zachary Ripley
      85 318i M50B25tu.
      92 525it 5 speed.
      80 244gl (m60 prepping).
      • WoozyGambit
        • Jan 2017
        • 5
        http://m.ebay.ca/itm/301881068951?_m...&ul_noapp=true
        • WoozyGambit
          • Jan 2017
          • 5
          Yeah thought that might work I'll go and rent one and give it a try. Thanks for the suggestion
          • FireFight
            • Mar 2012
            • 1367
            thats the exact one I bought, its a POS, it works, but not as easy to install as stock wheel or a real momo.
            you shouldn't have to use the locking nut to press the wheel on, should just slide on and then tighten the nut so it doesn't come off.
            WTB:m60b40 in PNW
            Zachary Ripley
            85 318i M50B25tu.
            92 525it 5 speed.
            • rcsoundn1
              • Nov 2012
              • 3361
              Man I was going to buy it as well. How does it look? Pics? Do you agree it's crap?
              • iPee
                • Nov 2013
                • 190
                For the peace of mind, I'd go with the momo. Getting a 3 jaw puller or renting plus time it'd probably end up costing the same as momo.
