camber problem
  • gilera_200
    • 131
    camber problem
    Guys, I think i have a camber problem cause my tyre is rubbing on my left hand side. As for the tyre size it's a 205/50/15. If looking from behing you can see the left tyre is straight while the right tyre is leaning inside( I dont know what the terms is hehe torque in or out maybe heheh). So the question is whether I need to replace the camber with an adjustable on or an oem parts?
  • IS
    • Jul 2005
    • 366
    Is this in the front or rear? If in the front, you either have seriously uneven ride height or damaged suspension components. If in the rear, Subframe/control arm bushings, or once again, something bent.
    87 325IS - Delphin Grey/Cardinal
    • gilera_200
      • 131
      its in the rear... do you have any pics for the problem mentioned?
