Sway bar end links for lowered cars.
  • Daeldalus
    • Nov 2012
    • 304
    I have a 90 325i lowered on h&r sports plus drophats. I noticed that the front
    end links were way too long for how low it is sitting. the bar is up at
    probably 25-30 degree angle. so i decided to see if there was any options out
    there to bring the bar back down to level. A level sway bar is better at
    reducing body roll. I think the math works out that you lose 4% efficiency if
    your bar is 15 degrees off and get progressively worse from there. at 30
    degrees off my bar has lost more than 10% of its ability to reduce body roll
    I work at a parts store, so i got out the Moog book and started thumbing
    through the pictures in the back. first i found that there aren't many end
    links made like the e30 ones. next i found that if you remove the bracket on
    the control arm that the end link bolts through you can use a different style
    of end link that is very common and has many different lengths available.
    they look like this.
    you would bolt the bottom part with the bushings through the control arm.
    may need to trim down the bushings a bit i haven't put them on yet.
    I got a bunch of them in different lengths sent to my store where i then
    matched them up against my current setup to see which would be best. I
    found three that seem like they would match up well with common setups.
    I will provide Moog numbers because they are common but you could use the
    house brand also if you wanted.
    For H&R Sport springs without drophats
    05-06 Chevrolet Equinox rear end links
    Moog number k80850
    For H&R Sport springs with drophats
    93-01 Nissan Altima front end links
    Moog number k9824
    ~0.5 inches shorter than the Equinox end link
    For H&R race or low coilover setups
    93-02 Nissan Quest front end links
    Moog number k8643
    ~0.75 inches shorter than the Altima end link
  • vpilarrt
    • Jun 2006
    • 2096
    Moog number k8643 - $1.83 ea at Rock Auto
    • Daeldalus
      • Nov 2012
      • 304
      also thought i would add that polyurethane bushings for these are super cheap and easily available.
      like these
      http://www.jegs.com/i/Prothane/311/1...FYZhfgodV6kIgA
      • Streichholzschächtelchen
        • Jan 2009
        • 1670
        This is awesome! I might be getting a set of these soon
        Jah bless! :pimp:
        • vpilarrt
          • Jun 2006
          • 2096
          Do you know if that's the right size for the Moog links?
          • Daeldalus
            • Nov 2012
            • 304
            I don't know 100% but i am pretty certain. those are the bushings that fit on the 'truck'
            style end links. like on many Chevys and Dodges and Jeeps. I had the Moog thermoplastic
            blue bushings for those kind of end links sent to the store to see if they would fit the end
            links that i was testing out and they fit. so I would think that the polyurethane bushings for
            the same vehicles would fit as well.
            I can get some of the energy suspension bushings sent to the store tomorrow or the
            next day and test fit those to check for sure.
            • Daeldalus
              • Nov 2012
              • 304
              I did more research today. Yaye!
              the tests were done on the Moog k8643 end links because i still had those
              laying around the store.
              I ordered a set of Energy Suspension 9.8106R polyurethane sway bar end link
              bushings. They fit snugly on the end link. They also will need to be trimmed
              down a bit because they are thicker than the original rubber bushings but i
              figure that you would have to cut them down anyway because of the additional
              thickness of the control arm. Also had a set of the Energy Suspension bushings
              with their metal washers too. Those washers are just a tiny bit too small to fit
              over the inside part of the k8643 end link, but would fit with very light drilling.
              overall i would say to just reuse the original washers.
              If you need a vehicle to reference that comes with these bushings then a 87-93
              Mustang is what i found them for in the book. The inside diameter of the
              bushing is 3/8 inch.
              I then went and grabbed a Moog heavy duty sway bar end link k7275. It says
              to have a 7/16 inch inside diameter bushing and are made of the blue
              thermoplastic that Moog uses for their HD line. Those bushings fit loosely but
              not sloppily and the washers fit the same. The bushings themselves were
              slightly thicker than the Energy Suspension ones and would require a little
              more trimming.
              Vehicle reference for those is a 94-01 Dodge Ram RWD front end link.
              From my tests i would say that any bushings fitting those specs would work.
              If i you can find ones that are made a little thinner then you may not need
              to trim them.
              • Daeldalus
                • Nov 2012
                • 304
                UPDATE.
                I decided to go ahead and buy some for my daily beater to see how they fit and how they worked.
                This is the before shot on the ground.
                I was able to install these by myself with the car on the ground and without modifying the links at all. Easy
                Here is the after install shot on the ground
                Much more level but not exactly..... But that is because I bought the ones for without drophats and this car has them too.... Whoops.
                Still they look great and are only about 0.5 inches from level.
                I do have one concern about them though.
                They stick through the bottom of the control arm a bit.
                I don't think they will hit anything but it is something I may correct later
                Picture of what I am talking about
                  • Jan 2009
                  • 1670
                  Which are these?
                  Jah bless! :pimp:
                  • Daeldalus
                    • Nov 2012
                    • 304
                    those are the K80850s
                    from an Equinox.
                    • Daeldalus
                      • Nov 2012
                      • 304
                      I just took them on a test drive.
                      I honestly didn't think i would be able to feel a difference when i wasn't driving them hard but they helped a bunch. felt great the whole ride.
                      • crash n' burn
                        • Nov 2014
                        • 211
                        just trim the bottoms if its a concern. I doubt you'll ever have a problem with them sticking down that far though, you're going to be hitting a lot more shit first..haha
                        I like it
                        -89' 320iT, Brilliantrot
                        -15' 320i, Glacier Silver Metallic
                        • z28
                          • Oct 2014
                          • 362
                          I replaced mine with oem links a few months ago, but when its time to replace them again I'm gonna try some of these.
                          First e30 - 1991 318i 4 door
                          • 5Toes
                            • 9836
                            great info. this is why I love r3v! thanks dude!!!
                            • Heitzke
                              • Nov 2015
                              • 132
                              Damn, yeah, nice find there. Angle of the way looks much much better.
                              '89 318i Touring
                              '90 Miata
