E36 Rack Conversion Question
  • Powling
    • Jan 2015
    • 1290
    Just looking for confirmation on what I've found during research before ordering a kit to install my E36 rack...
    On airbag cars (I have a 91 318is), you don't require modifying the steering connection correct? All you need are the rack spacers? Does this still apply if I am changing the steering wheel out to an M tech I wheel? I don't think it matters but doesn't hurt to ask!
    Steve • Toronto
    1991 318is • Brillantrot
    Build Thread
  • z28
    • Oct 2014
    • 362
    All you need is the spacers and to grind the firewall.
    First e30 - 1991 318i 4 door
    • mtech325
      • May 2008
      • 569
      Like z28 had said, for the rack swap, you simply need to use the rack spacers and to grind out the firewall a bit for the shaft to clear properly. No linkage modification is necessary for airbag cars.
      For the steering wheel itself, you just need and extra spacer, part # 32-31-1-120-260, and it can be bolted up like any other steering wheel, regardless if the rack is stock or an e36 unit.
      • Powling
        • Jan 2015
        • 1290
        Thanks guys! Exactly what I needed to know.
        While on the topic - is it worth doing a guibo delete or does it have much effect / benefit at all? Or is it better to just go poly with an IE guibo?
        Steve • Toronto
        Build Thread
        • dude8383
          • Jan 2005
          • 10387
          I'd stick with the rubber guibo there. If it were a track car the poly one would be the way to go but for the street I think it'll be a bit too harsh.
          • Powling
            • Jan 2015
            • 1290
            What exactly makes it too harsh for street use? Does the feedback from the road (potholes, cracks, etc..) come through the wheel more noticeably?
            Steve • Toronto
            Build Thread
            • dude8383
              • Jan 2005
              • 10387
              Yep. The rubber does a better job absorbing that stuff. Your "tolerance" may vary though haha.
              • Powling
                • Jan 2015
                • 1290
                Haha good point. Since my E30 is only for weekend fun use and not daily driven, I might try the poly guibo and see if its tolerable. My guibo needs to be replaced anyways whether I go OEM or poly.
                Steve • Toronto
                Build Thread
                • dude8383
                  • Jan 2005
                  • 10387
                  You'll probably be fine with it but again people's tolerances may vary + location matters too. Roads can be great in one location and shit (like here in NY) in others.
                  • pawa_k2001
                    • Jul 2015
                    • 56
                    I did this modification to my 1991 325i recently. You need the spacers and firewall needs a little work.
