Sway Bar Advice Needed
  • Bimmerguy91
    • Jul 2012
    • 982
    I am needing some advice on what sway bars I should run. I have been looking at the ST 22mm front and 19 mm rear sway bar kit.
    Details on the car:
    S52 swap
    H&R Race springs w/ Bilstein Sport shocks
    80a polyurethane rear subframe, rear trailing arm, differential and front control arm (centered) bushings
    Adjustable rear subframe
    I am going to do a mix of street driving, autocross and occasional track days with the car. More street driving and autocross than anything.
    So, R3V, what do you say? What size sway bars should I run?
  • SkiFree
    • Jun 2011
    • 2766
    For heavy autocross use I'd recommend 25/19 (IE will do it via special order). ST's are ok, but if you are doing it right, you are using the IE setup. 22/19 is fine. Just depends on your driving style.
    ADAMS Autosport
