Hello All,
I've recently attempted to swap my blown steering rack for a z3 1.9 e36 rack on my '89 325i.
I'm nearly at the finish line but I've got this kink on the line from the rack to the reservoir(return, thinner diameter hose).
I was wondering if any of you had advice for me on either routing differently, or if I have to resort to bending the metal pipe before the flexible hose?
Here's a snapshot of the problem. The green arrow shows the kink and the blue circle/box is where I'm thinking I need to straighten the bend...
I was hoping I'd be able to slightly straighten the bend, to alleviate the kink in the hose, with some straps and pulling while everything was tightened down, but that didn't work out so well. My next thought was to heat the pipe and try again, but I seem to run across lots of people online recommending to not heat these pressure lines.
So then my next thought is to take the line out again and straighten on my bench.
What's the safest way to do that without risking a kink or crack in the metal pipe? Fill with sand and use a proper tool? Or can I do it by hand with a vise?
Any recommendations from those who have run into a similar problem?
Thanks in advance for any feedback!
Happy new year!!
Happy new year!!
