Koni Yellow Bump Stops
  • Powling
    • Jan 2015
    • 1291
    Just curious how much I should cut stock (non sport) bump stops down for Koni Yellow Sports...and can I use the cut off portion in place of the rear bump stops?
    Steve • Toronto
    1991 318is • Brillantrot
    Build Thread
  • Powling
    • Jan 2015
    • 1291
    An update here for anyone needing the info in the future.
    I ended up cutting OEM front bump stops for up front, roughly 1.5in of the stop was cut off. I've put over 1000km on the new set up so far and haven't noticed any negative effects from this at all so far.
    For the rears, turns out that they have small black rubber bump stops included from factory. I left these in and all is good. Only issue with these ones is they like to get pinched every time I let the car down after jacking the car up. The bump stops end up getting caught on the upper sleeve when the car is let down with the jack. The only resolution to this I've found so far is to SLOWLY let the car down in stages and double check the bumps aren't getting pinched as they go down. Time consuming but its the only solution I've found so far.
    Steve • Toronto
    Build Thread
