ST E36 coilovers VS Ground Control coilovers
  • Motheye99
    • May 2018
    • 853
    Hello,
    I know someone selling a brand new set of ST E36 M3 coilovers and some ebay camber plates, for 450$ I Also have 318ti trailing arms so I could easily finish the setup.
    So i could probably finish the setup for 900-1000$
    BAV auto is having a sale on Koni adjustable shocks and for 4 its 500$ GC's are 500$
    So 1000$ give or take
    So my question is how much of compromise is running a E36 5 lug in suspension geometry, I've read there is issues unless it is done properly.
    Thanks
    91' 318is 90' 325is
    Originally posted by Sonny
    Buy the E30s, they ain't gonna last long
    E30 can make you, E30 can break you
    "He who controls the Nova's, controls the Boomers"
  • Blackout
    • Apr 2011
    • 4130
    Why do you want to convert to 5 lug? What are you looking to achieve ?
    Just suspension upgrade? or Upgraded suspension, brakes, wheel selection, etc.
    » PARTS FOR SALE
    » TRANSACTION FEEDBACK
    • Motheye99
      • May 2018
      • 853
      I'm not really concerned about ether its 5 or 4 lug, theirs a kit that convert teh hubs and brakes from 4 to 5 lug that is reasonably priced. I'm asking if compared would the E36 ST coilovers vs the Groundcontrol's, which would be the better buy. I figure they'll probably e comparable in the end for both setup's.
      91' 318is 90' 325is
      • Blackout
        • Apr 2011
        • 4130
        Ground control because it is a modular setup designed for e30. You have the option to pick from available spring rates and various shock inserts. And if you go with koni or bilstein, they are serviceable.
        With e36 ST, you are locked into whatever they are configured to.
        » PARTS FOR SALE
        • Jb325is
          • 2137
          Well it sounds like he is just talking about GC sleeve kit and off the shelf Koni's... Which is how GC gets a bad rap with some people around here. A true GC kit is shortened housings, re-valved Koni's, GC camber plates and rear mounts, which is an awesome street/track compromise setup.
          I'm not a fan of e36 stuff because of the offset, and wonky front geometry but for a street car that doesn't really matter at all.
          Maybe look into BC's as well. They are garbage IMO but some people seem to like them and they can be purchased new for under $1k.
          - '88 m54 coupe
          <3
          • mwagner10702
            • Jun 2018
            • 49
            Ground Control just recently released a coil over kit that includes a set of engineered / fabricated front strut housings so you don't have to chop yours up to go full coil over. This is a great option for those who want to retain their OEM front strut housings in case they ever want to go back.
            I have the GC coil over kit on my E30 M3 (yeah, i know, slightly different suspension than a non-M car) and it is great. I'd definitely recommend it.
            1990 M3
