Some intall questions
  • Mike325
    • Mar 2006
    • 3685
    So right now I am rebuilding my front suspension again with some nice bilstein shocks I got in the mail today, as well as some other strut related stuff. I know that the stock shocks had oil in the strut to help with shock cooling. Do I need this with the bilstein shocks? Where can I get the tool to get the threaded collar on/off? Last one, how do I keep the shock shaft from spinning ewhen I tighten the top nut?
    Thanks.
    Originally posted by Kershaw
  • tonytony
    Knee deep in poopie
    • Jan 2004
    • 3498
    cut a slit in the collar nut, put a screw driver on it and tap it with a hammer. When i did my suspension i got new hex gland nuts so i just used channel locks to tigheten it. Maybe you can try to flatten the nut so you can get a channel lock on it. to keep it spinning i only tighten it until it starts to spin, i never had a problem with it yet
    • StereoInstaller1
      GAS
      • 22679
      intall?
      Closing SOON!
      Thanks for 10 years of fun!
      • Mike325
        • Mar 2006
        • 3685
        intall?
        LOL, I fix;)
        • Ferret
          • May 2005
          • 101
          If you don't want to buy a special tool, you can either use a plumber's wrench or an angle grinder key wrench (insert one pin into one of the holes in the threaded collar and push the other pin against the rim of the collar).
          There sould be a hex on the top of the shaft. You should use one hex tool (socket, wrentch etc.) to hold the hex and another to tighten the nut.
          You can also do the final tightrning of the nut with everithing installed and the car on the ground. the weight of the car will keep the shaft from spinning.
          • Mike325
            • Mar 2006
            • 3685
            Exactly what my teacher said this morning. Thanks for the help.
            • Mike325
              • Mar 2006
              • 3685
              Update: Got it all installed without a hitch. Thanks guys:p
