E30 GC Rear Adjuster
  • cbett1
    • Nov 2013
    • 17
    Does the rear control arm get drilled for the adjuster hat? If so, I would have to drill a big hole for the bolt head and socket to hate through the bottom ca, then a small hole for the bolt threads to go through and attach to the adjuster hat.
    Sent from my SM-G975U using Tapatalk
  • cbett1
    • Nov 2013
    • 17
    Discard the bolt, that's for e36 ta's. Lower co mount just sits on top of the lca hub per gc.
    • nrubenstein
      • 3148
      There is absolutley no need to bolt it down. Once it’s been loaded, removing it requires a pry bar, some penetrating oil, and a little patience if you don’t want to gouge the crap out of things.
      2002 BMW M3 Alpinweiß/Black
      1999 323i GTS2 Alpinweiß
      1995 M3 Dakargelb/Black
      - S50B32/S6S420G/3.91
      1990 325is Brilliantrot/Tan
      1989 M3 Alpinweiß/Black
