FIY: the MZ3 has an 18.5mm sway bar that looks similar to that. I found it available for $120 brand new. I've also wondered if it's a direct fit but I never got a direct answer.
Already looked into that too my friend has one and he says he will give it to me to try. However it bolts differently but im sure i could make it work seeing it is similir shape/setup
If you could please keep me posted with your findings, that would be great. I am interested in seeing how that would work out.
I removed lots of weight from the front more than 50 pounds worth easy.
No A/C compressor, no lines,no receiver /drier, no washer resevoir. The car Handles very good already.
However i do need stiffer shocks in the back (ex. Bilstein, Koni) Im using cheapies right now . I am using e36 m3 H&R race springs in the back which are awesome.
yes sway bars reduce body roll, but it's a better practice to go with stiffer springs first, then do larger sway bars if needed
I've taken the opposite approach due to the fact that I have a sewer rat instead of a track rat. I am running soft springs, stiff bar, Bilstein Touring shocks, and an E36 rack.
I can go over bumps, dips, potholes, etc. without banging and bouncing. The bar and E36 rack keep it flat with quick turn-in. The car rides good and has excellent feedback. I do most of my driving in town and under 50 MPH. The car was absolutely horrid with 350# fronts. They were just too stiff for the street.
