I would like to thank anyone in advance for providing any kind of input on the matter(s)
1. Would I be correct in my assumption that, as of this moment, the only vendor that supplies top adjustable Koni's for all four corners would be TCKline?
2. If my intent is to pair the Koni's with H&R sport springs, would the employment of a larger than 5mm spring pad in the rear, perhaps something like 9mm or greater, help to equalize drop height in the rear to that of the front?
I have noticed that in the stock "4x4" height, the rear appears to be a bit lower than the front, and with consideration to the fact that the Sport set is an equal drop of around 1.25-1.3" for both front and rear, I am left assuming that I will be stuck with the same proportionality just 1.3" lower.
