Eibach Sportsline v IE stage 3
  • damith
    • 422
    from what I know these 2 products r the same thing, but different names.
    am I right or wrong, pls confirm..
    damith
    [All the Bronzit haters]
  • JJe30
    • 2044
    I believe that is correct. Eibach makes IE's springs.
    • Jand3rson
      • 37587
      Stage III springs are the same spring rate as H&R Race, but I've never heard of the Sportsline. Are they the same?
      • doucy2
        • Sep 2006
        • 1311
        while we are on spring rates aren't tokico the same rate as IE's?
        • damith
          • 422
          Sportsline
          i think eibach sportsline and IE stage 3 is the same. in that case IE is charging $295 is bit over priced 'cos i saw couple of sites sell Sportsline for $235.
          • Axxe
            • Aug 2004
            • 3355
            Pretty sure Pro-Kit = Sportline approximately. I don't think they are the same, so I'd just go for the IE's.
            Keep it slideways!!
            • tonytony
              Knee deep in poopie
              • Jan 2004
              • 3498
              tokicos are not the same as IE's otherwise i wouldnt' have sold them to you;)
              • damith
                • 422
                OK i checked with Eibach and coplue of other ppl. No the pro kit and the sportsline is not the same. sportsline drops the car more than pro kit does. to be precise, while pro kit drops 1''-1.5'', sportsline drops 1.7''-2.3'' (depending on the make of the car)
                but my question was IE stage 3 and sportslines is the same or not?
                if anyone can post the part # of IE stage 3 springs it's a gr8 help
                thanx
                damith
                • PiercedE30
                  • Apr 2005
                  • 4220
                  did you find out what the spring rates were?
                  My 2.9L Build!
                  • doucy2
                    • Sep 2006
                    • 1311
                    here you be
                    • BrandC
                      • Jul 2006
                      • 444
                      I sure hope you aren't mixing up IE stg. 3 Spec E30 springs up with those pansy-ass sportlines. You will disappoint yourself if you buy the latter.
                      -Brandon
                      • Jand3rson
                        • 37587
                        Add another inch to that once the they sag down after a year or so, like the Pro Kit.
                        What I was under the impression of was that Eibach specifically made the Stage III's for Ireland Engineering, and they're the only ones that distribute them. Other places sell them, but they're still Ireland Engineering.
                        • damith
                          • 422
                          So that means Eibach purposely make bad products under their brand (Sportsline) and make better products under IE (in this case?)
                          :drink: suprised.
                            [QUOTE][So that means Eibach purposely make bad products under their brand (Sportsline) and make better products under IE (in this case?)/QUOTE]
                            No, the springs are made for different purposes. The IE Stage III springs are meant to be a race spring with race spring rates.
