hi. i'm new to this forum but have had a good read around it and am impressed so far :bow:
i have a 325i touring with a 3.5 M30 conersion and i'm having a lot of fun with getting the correct suspension setup for it, understandably as it's a fairly oddball weight distribution!
currently it's about -40mm at the rear and -70mm at the front. a lot of the front drop is due to the engine and i also believe the unkonown springs are for a 4 pot touring as they're so soft! when braking, it hits the bottom out stops on the front! it also has koni adjustable shocks at present.
as the front is too low and too soft, i am thinking of doing a coilover conversion so i can fine tune easily but have trouble finding what spring rates to start off with.
does anyone know what rates the bmw springs are?
does anyone have and advice on spring rates for the heavier M30 at a -50mm ish drop?
cheers in advance!
cheers in advance!
