But, when people cut the strut housings to shorten them for more lowering with still maintaining shock travel, you lower the perch and sometimgs you actually require a lower offset to clear that perch. That happened with 4ce30 when he tried to shorten his struts 3 or 4in.
No coilovers on 16x9 +15?
Originally posted by backtrail69 View PostThat is a very informative article. I am looking to upgrade to coil overs this summer on my 325is and that helps a lot to understand more about them.Reminiscing...
Yah, I forgot to bring that up. Bilsteins + no camber plates = forget it. Most people are going to spring for konis anyways though, since those are pushed along with most coilover kits.
Even still, I wish for more travel, but refuse to use koni SAs over custom valved bilsteins. Suspension travel is simply one thing the e30's strut design doesn't excel in - which is perfectly fine for relatively stock ride heights. Previous cars I've owned, like the porsche 944, have longer springs and a longer strut stroke, which copes with lowering a lot better.87 325IS - Delphin Grey/Cardinal
So how do you go about the fab on the GC's with say, Koni's? And can you still keep stock height on the Konis and still be able to lower the car considerably, or is it better to shorten them? I dont really like the idea of shortening the strut, it sounds ghetto.
Oh and i appreciate all of your guys imput on this!
You don't HAVE to shorten the strut.
If you don't want to slam it all the way (which you will) you dont even have to cut the perches
Most have coilovers for stretched tires on fat rims because you need really rolled fenders and a perfect height setup. You don't want to buy the rims, add a couple spring pads and still rub, then have to buy coilovers.
That happened to a friend of mine who had drop springs, when he bought 18's they had to sit in his garage for 6 months while he saved up for coilovers, because he needed to raise his car to fit them.
I have GC's with matching camber plates and koni SA's (rear is top adjustable too) and it r0x my s0x
Hey guys, I ran KW 60/40's with deeper spring hats in the front, perfect stance for the wheel and tire combo, dampers were Bilstein sports, as far as decreased travel goes, I never bottomed the car out or had any handling issues, it handled quite well actually and I didn't have to run aftermarket sways.
