M3 Swaybar Links
  • Skafrog
    • 1732
    M3 Swaybar Links
    I was looking around the web for an article on converting to M3 swaybar links up front, but I did not find very much info on it. So far, I gathered that both the m3 and the iX used the type of swaybar links which mount on the strut, correct?
    I know this was a topic on e30sport a while back, but I was wondering the stock front swaybar would be too stiff with an m3 style mount.
    Also, would e28 sway links work?
    Thanks
    NASA MidSouth TT Director / GTS2 #018
    Mods: Coastal PS Fluid, 10w40 Oil
    Future Mods: Bosch Micro-Edge Wiper Blades, Painter's Tape, Spark Plugs, Freezer for Nutty Buddys, Adam Nitti CD's
  • Stu Mc
    • 4083
    Re: M3 Swaybar Links
    Thanks
    Yes, you can use M3 links. You can pick them up at the dealer for about $15 a piece (need 2). You'll need to weld brackets on your strut housings, so you can bolt up the M3 link. Ground Control (www.ground-control.com) sells these for $8 each (need 2).
    • Skafrog
      • 1732
      thanks alot. Looks like a trip to the $tealer will be in order this weekend.
      • Stu Mc
        • 4083
        Here's a couple pics of my setup.
        You'll be fine with the non-M front swaybar. I use a 22mm front bar with no problems, the ball joints in the front links are still in excellent condition (after 1yr).
        hth
        • Skafrog
          • 1732
          did doing this make it stiffer, and did you have to run a different rear bar to compensate?
          • Stu Mc
            • 4083
            Makes it a lot more responsive and composed. Cause ya know you gotta keep your composure out there (frank). I run a 19mm adjustable rear bar (tightened up) to compensate. I could stand for a little more rear bar though. Maybe a stress bar, dunno.
            • James Crivellone
              Head Janitor
              • 6304
              hehe I am doing this in 2 weeks, already have hte swaylinks, just gotta weld the tabs on
              • rs4pro3
                • 5808
                Same, here I've got the links and tabs sitting but haven't found anyone to weld them yet.
                85 325e 2.7 ITB'd stroker
