I submitted somewhat of a procedure on how to rebuild your PS Pump in the DIY section but it either never got reviewed, got reviewed and wasn't posted or whatever. Regardless here's some info for those who are interested. This is more to let everyone know how easy and inexpensive it is to rebuild than to buy new or used.... I show the kit's list price as 32.75. a New/remanufactured pump on the other hand lists $220.
Note: both pumps on my 90 325is and 92 325i Cabrio were Vickers however I also show there was a ZF pump used on some E30s. This applies to Vickers. Based on the diagram I've seen of a ZF pump, the repair should be just as easy if not easier.
There's hardly much to change: 6 O Rings, a small C Clamp and a retainer seal.
Everything taken apart:
you can see here where the 1 largest O Ring goes, the two next to largest go and 1 of the 3 small one goes (small hole next to 1 of the 4 bolt holes)
the two remaining small O Rings go here at the fingertips (remove with small allen)
flathead the old retainer seal out here and hammer in the new one with a 20 or 21mm socket.
Pay attention to the orientation of things as you take the pump apart and as they say the rest is reverse. Rub some of that evaporating/melting whatever grease (I used that trans prep blue grease in the pic) on the parts that are metal to metal just to fit them back in easier and Voila... New PS Pump on the cheap and easy...
