Koni Question, IE3/TCKline
  • EWAustin
    • Sep 2006
    • 234
    OK, I'm going to be running IE3 springs, and am looking to order Konis soon.
    Question, are the standard Koni Sport shocks short enough to run IE3 springs? Or will they bottom out?
    Also, I seem to remember reading somewhere that TCKline sold the only externally adjustable rear shocks for the E30 chassis. Does anybody have experience with these?
    Thanks in advance,
    Eric Austin
    1990 325i Sterling Silver
    ///M3 CABs | ///M3 strut bearings | Bavarian Autosport springs | UUC Race Shifter | UUC Clutch Stop
  • SchnellerVert
    • Sep 2005
    • 3948
    TCK is not the only source. The rear Mustang after the fox body uses the same length and is DA.
    • EWAustin
      • Sep 2006
      • 234
      I'm not looking for DA, just SA, but that Mustang info is good to have.
      I'm assuming it's basically bolt-in?
      Just one last question then, with IE3 springs, do I have to worry about bottoming out Koni's or are they short enough that they won't hit?
      Eric Austin
      • SchnellerVert
        • Sep 2005
        • 3948
        TCK and IE package the Koni's with the Springs so I assume that they should be good to go.
        • e30sd
          Fistee
          • Jan 2004
          • 5517
          you'll be fine. the only time you'll run into that issue is you're using a coilover spring.
          • EWAustin
            • Sep 2006
            • 234
            Good to go guys, Thanks
            Eric Austin
            • Mike@PureMS
              • Oct 2006
              • 221
              You'll be fine with the KONI's on those springs.
              We've got them available with free shipping, check out our website!
              Mike
              www.purems.com |Temecula, CA | 866-397-5487
              • EWAustin
                • Sep 2006
                • 234
                Are your rear Koni's externally adjustable?
                Eric Austin
                • e30devo
                  • Aug 2005
                  • 1102
                  i run IE3s on oem replacement shocks and ihave no problems whatsoever with them.
