H&R Cup Kit users post here.
  • egk2
    • 2426
    Do you actually like your cup kit? Post your reviews here.
  • backtrail69
    • Jul 2005
    • 4471
    I'm assuming this has to do with BMW Dudes retarded replies on the tech..
    TOO SOFT! You can't go low and soft... thats how you break pans...
    :: PNW Crew ::
    '87 325 4dr, '74 2002
    • egk2
      • 2426
      Not so much in repsonse to him but I want the kid thinking about running the kit to read some other people's opinions on it besides mine.
      • e30xcel
        • Aug 2004
        • 141
        I wish H&R would just revise the kit and stiffen up everything.
        hellaflush x driftunit
        • SchnellerVert
          • Sep 2005
          • 3948
          This kit is more oriented at the smooth roads commonly found in Germany. Not our pot hole battle zones we call roads and highways.
          Seriously our roads are junk as they get little to no maintance, bridges are falling, rutts in the pavement from overloaded trucks due to lack of weight enforcement.
          Dan Gillian had good luck with his FK kit awhile back. He said it was quite stiff and was still streetable.
          • loonibab325i
            • Dec 2005
            • 770
            MANN, drop this haha, u know what i think though ;)
            s52 0-150mph & more http://www.youtube.com/loonibab325i
            • E-rich
              • Jun 2006
              • 982
              :tsk::down: o so soft and not worth it.
              Originally posted by rwdrift
              Back to E-Rich's car and drifters. His car is baller, purpose built. Posers are fags. KA-Ts suck. I like beer. And I need monies.
              - Erick
              • James Crivellone
                Head Janitor
                • 6305
                I run it, with ST Sways, Offset Urethane CA Bushings, and Urethane Trailing Arm and Subframe.
                Its fine for me, handles fantastic, the sways removed quite a bit of roll, and the car responds how I want it. I see no point in changing it out at this point.
                • 92 mtechnic cabrio
                  • 4907
                  HOW TO BREAK OIL PANS:
                  Step 1) Buy an E30 (6cyl, cabriolet preferred)
                  Step 2) Buy and install H&R Cup Kit
                  Step 3) Back out of your driveway.
                  That's it!
                  After driving my car, and then an E30 with a real suspension setup, I definetely see how much brighter the light is. Butttttt, I'm so addicted to the slow, low, and floater look!
                  R.I.P 07/01/09 - 04/23/10 :(
                  • blueapplesoda
                    • Dec 2005
                    • 1904
                    cup kit is very soft, but for a stock 325 at the track with some urethane bushings, the soft just helps with traction. when running street tires.
                    Ibut i too like it lowww...low with lippage, stretched tires or squared...w/e...just lowwww and flush. I need to roll my fenders moar!
                    • egk2
                      • 2426
                      motor is looking awesome in your sig, I haven't been keeping up on your build up, is your e30 done?
                      The question I should ask you cup kitters is if you could do it all again would you have chosen the cup kit? Be honest.
                      • fretburnr
                        • Jan 2005
                        • 1496
                        I've had it on now for close to 2 years. I run it daily on the nasty streets of chicago and 'burbs...
                        I honestly don't mind it. Yes, it is soft- i do find that it rolls too much and that the front end bottoms on really hard bumps. That being said, it handles relatively well; not perfect by any means, but it's fun.
                        If i had to do it again i'd go with IE3s and Konis, provided coilovers were not something i was interested in at the time, and i wanted to stick with a shock/spring combo. It's strange, the cupkit's shock valving seems quite stiff given the spring rates; i think that konis with a stiffer spring would be a much preferred choice for handling as well as ride.
                        In the meantime, I won't be changing it out soon as I've got other things that need my $ first. However, i picked up some ST sways to reduce some of the roll; hopefully that will satisfy me until i've got available funds for GCs.
                        Jay
