Bilstein vs Koni vs Illumina on 450/550
  • etxxz
    • Feb 2006
    • 2085
    So i'm finally going to spend some major $$ and do the suspension and also going to drop the rear subframe to do the bushings and have a few questions on which shocks could handle the springs rates i want.
    Did hours of searching and came up with NO info on the illuminas on e30's and then found plenty of info on koni vs billies and ultimately their performance on a chart:
    Now my major concern is that the info i found online about the koni's is that they are good up to 450lbs springs and that after that they dont have enough dampening (that's the warranty speaking) I just want to know what shocks i should get with a 450/550 or 500/600 setup and wether Tokico illuminas (adj) will do the job beucase my friend wrecked his convertible and i have access to a cheap set of new illuminas. *I DO NOT WANNA BOUNCE AROUND ALL DAY LONG*
    I know i can revalve the billies but would rather not spend the extra money for this service or the koni's...purpose is track and plenty of street driving
    Thanks for the help i just oculn't find any more info and i wanna do shit right the first time!
    No more e30s for me.
    88 black BMW OBDII 332is dedicated track [sold]
    88 BMW OBDII bronzit 332is [RIP 03/08]
    91 BMW 325i [sold]
    86 Corolla 'Ae86' HB 20v trd [sold]
    http://youtube.com/watch?v=pTj7Hn9v5Rs
  • etxxz
    • Feb 2006
    • 2085
    talked with bilstein and they didnt recommend i run the sports unless i get them custom valved as it will void my warranty so i got some koni's w/ rear ext adjustable for $517.20shipped and said fuck it since nobody here had any imput on the tokico illuminas
    now to my bad luck i just ordered bushings and was checking under my car to see what else i should order/repair while i'm down there and turns out my car already some red trailing arm bushings ($70 down the drain!) i coulnt see them before 'cuase they were covered in black...the rear subframe bushings are fine but some IE streets won't hurt.
    91 BMW 325i [sold]
    • e30 gangsta
      • 3877
      the subframe bushings is were the money is @ enjoy and i must get a ride when you install everything. :)
      • backtrail69
        • Jul 2005
        • 4471
        I have the Tokiko's on my car. I am not all that impressed with them. My bilsteins seem to ride much better on my eta w/ stiffer springs. I will try the Konis next.
        :: PNW Crew ::
        '87 325 4dr, '74 2002
        • CarsSuck
          • Oct 2005
          • 968
          my brother has koni/H&R sprts on his e36 and it rides way better than my e30 does on bilstein/H&R sprts
          --Will
          • etxxz
            • Feb 2006
            • 2085
            i started yesterday and dropped all of the suspension and CAB. The rear shocks will take a 3-4weeks 'cuase they're sold out everywhere...so sorry for my current shocks. will rip them bushings today. THIS IS A ONE MAN JOB
            droped it with diff and everything
            and this is what happens when you try to take a pic around a load of crap
            91 BMW 325i [sold]
            • browntown
              • Jun 2004
              • 3524
              whoopsies. done similar, laughing with you.
              • joshh
                • Aug 2004
                • 6195
                Just to let you know.....you made the right choice!
                Illuminas are a bit better than KYB AGX's but inferior to Koni's.
                Have fun, good luck.
                "I cannot undertake to lay my finger on that article of the Constitution which granted a right to Congress of expending, on objects of benevolence, the money of their constituents. Charity is no part of the legislative duty of the [federal] government." ~ James Madison
                ‎"If you've got a business, you didn't build that. Somebody else made that happen" Barack Obama
                • matt
                  • 3732
                  Where did you find that graph? Is it for the fronts or rears?
                  I don't really trust it...
                  • etxxz
                    • Feb 2006
                    • 2085
                    found it looking at R3v's countless bilstein vs koni threads:
                    post: http://www.r3vlimited.com/board/show...91&postcount=9
                    THREAD HERE
                    source says depaul university (???)
                    i have good news...i will have the privilege of trying out both koni and illuminas because my externally adjustable rear shocks won't be in for another month so i'll ride on these for the time being and will post results when i change.
                    91 BMW 325i [sold]
                    • e30sd
                      Fistee
                      • Jan 2004
                      • 5517
                      hey etxxz
                      how did you pull the ebrake cables?
                      • etxxz
                        • Feb 2006
                        • 2085
                        Just a little update, turns out my "red" bushings were KMAC lol so idk i replaced the subframe and left the Kmacs (EZ adj!!), having LOTS of problem getting the control arm bushings back on the car w/o the right tool (anyone got tips??) and i proceeded to start my strut coilover conversion. still waiting on springs and shocks to arrive:hitler:
                        Originally posted by e30sd
                        hey etxxz
                        simple from inside the car, remove the plastic console that cover the e-brake assembly (one nut). Then remove the two 10mm nuts for adjusting the e-brake cable and manuver the line/cable from under the e-brake handle and pull from outside...remember there's 2-3 tabs holting the cable from under the car, just un-tab them d:
                        i just hope your car doenst have much rust...there's a sleve where the cable connects to the cabin and one on the hub and i spent 8hours with a dremel eating though metal on my last e30 to get these loose!! that's why i ove my current e30 not a hint of rust LOVE IT!!
                        91 BMW 325i [sold]
                        • e30sd
                          Fistee
                          • Jan 2004
                          • 5517
                          yea it seemed simple, except the donor car had rust in the same spot which made it a bitch. had to use a little jig saw to buzz through.
