I just installed:
H&R Race springs
Bilstien Sports, front and rear
M3 rubber offset CAB
New tie rods
New urethane rear shock mounts
IE Camber plates in the front
Now I have a clunk coming from the right front wheel area. My sway bar bushings and end links are shot to hell, but I also had no clunk before the new suspension. The clunk happens when I unload the suspension slightly after a stop, just before I have stopped completely.
Pretty sure everything, including strut collars, camber plates, calipers, etc are all tightened down well.
The front right rotor is missing its retension screw, but I can't imagine the rotor is shifting with the wheel bolted down.
What are the possibilities? Is it possible the sway bar is now an issue with the large lowering? I have plans to replace in the near future anyhow, but it was odd that this appeared after the suspension install. One other thing: I did have to go with a new used strut housing and wheel bearing since mine was rusted to oblivion. Wheel bearing seemed good.
Another thing: When I jack up the left front corner, the spring (which is too short to be captive) falls out. Not so for the right side - the spring stays stuck. Not sure what holds it in, I guess just the friction of the rubber betwen the spring and the upper and lower spring perches?
Anything I have not thought of?
Thanks!
-E
H&R Race springs
New tie rods
Thanks!
-E
