Diagnosed rear end noise...
  • jex
    • 285
    It is my freakin swaybar that sounds horrid! It is these bushings (red)....any way to lube it up? :)
    My car sounds like it is fallin apart!
  • jex
    • 285
    Or is there anywhere that sells just the bushings???
    One more question. The point where the swaybar links bolt to the swaybar seems "loose"....it just doesn't seem like the bolt isn't tight enough or something. Is this normal??
      The bushings are available from your dealer for about $6ea. You have to know the diameter (in millimeters) of the sway to get the right bushings.
      • mattdk318i
        • Jun 2006
        • 3953
        I was just making comments about using rubber instead on sways. This weekend if i recall correctly.
        • ToplessE30
          • 4791
          rubber > urethane
          Estoril E36 M3/4/5 | Toledo E53 X5 3.0 | LeMans E90 335D M-Sport
          • redhatpat
            • Aug 2005
            • 656
            Originally posted by ToplessE30
            rubber > urethane
            If the car is anything less than a dedicated track car, I absolutely agree.
            • Garageaholic
              Freestyle Fabricator
              • Dec 2005
              • 5204
              Oh man, i remember putting my `19mm rear sway bar links on ... It was one of the hardest things to install.
              They were the red urethane bushings. I love them actually. Couldn't be happier and I don't track my e30
              Recent Rebranding!!
              E30 SM62/S62
              E30 M60 V8
              E30 M30 Big 6!
              Instagram.com/garageaholic
              Youtube.com/garageaholic
              • BigFurryWhale
                • Jun 2006
                • 282
                Is it really that hard? Got any tips? Any write up somewhere i can follow?
                • mattdk318i
                  • Jun 2006
                  • 3953
                  rubber > urethane
                  i would agree;)
                  • jex
                    • 285
                    Yea...im pretty sure its a 19mm bar (suspension techniques). I think I'll probably go with rubber. Does the dealer carry bushings in this size?
