Im currently building up a 335i and I am curious what springs/rates people are running. Any suggestions/ advise would be great!
What springs for 335i
Normal springs should be fine, H&R, Eibach, whatever you would use in an M20 powered car as long as you do not have AC... With AC I think they would still work, but you may be better off with a GC setup and some heavier duty springs up front.'88 528e /// '88 M5 /// '89 951 /// '98 E430 /// '02 M5Comment
I installed IE stage 3 in the 335e. I have'nt had a chance to really wring them out yet since the tires and brakes are all brand new and need to be broken in a bit, but a zip on the back roads through the nearby onion fields showed promise. The stance is perfect and the car does not feel overly nose heavy, albiet with an addmittedly limited test run.Comment
