Stock sways, poly bushings
  • Mike325
    • Mar 2006
    • 3685
    So I was thinking of just getting some polly bushings and keeping my stock sway bars. Would this be a noticeable difference or am I stuck getting a bigger bar?
    Thanks.
    Originally posted by Kershaw
  • e30 gangsta
    • 3877
    Anything is better than 20 year old worn bushings
    • g22
      • 274
      I see bmp sells polly but what size are the stock sways? I was thinking about the same thing. I have an '89 325i...
      • CarsSuck
        • Oct 2005
        • 968
        my brother did this on his e36 and said it made a difference.
        just my
        --Will
        • JRKOUPE
          • Dec 2004
          • 3159
          bushes
          Itll make a diff.....especially over old ones ( as said)...they may squeak as well a bit.
          but what is your goal?.....get new oe stuff if not a track rat.......mine is a track rat.....and I used rubber.
            Urethane sway bar bushings aren't going to do much over OE bushings in good condition. If the goal is the reduce body roll you need stiffer springs, sways, or both.
            • jtb_29
              • Oct 2006
              • 273
              These should work. Stock front bar is 19mm right? Or is it 20? I forget..
              The grilles really distract you from the fact that someone took a sledgehammer to the front end.
              • BrandC
                • Jul 2006
                • 444
                http://store.summitracing.com/partde...5&autoview=sku
                Is that even for BMW's? Just because the ID of the bushing is right does not mean it's universal...
                -Brandon
                • StereoInstaller1
                  GAS
                  • 22679
                  The Energy bushings DO NOT FIT the E30 mounts.
                  I welded a plate under the stock mount location to make the energy mount work, but have not yet installed that subframe.
                  Closing SOON!
                  Thanks for 10 years of fun!
