How many of you running H&R sports are also running camber adjustment of some kind? What kind? To those without camber adjustment, are you encountering any significant tire wear?
camber plates needed for H&R Sports?
Tags: None
Good to know. I made the mistake of trying to add up all the parts I will need to buy for the 'vert project, and the number made me want to crawl under the desk and cry. So if I can save $150 and not go with adjustable camber plates, I'm all for it. I don't have any on the coupe and it seems to be fine, but it's also riding on big floppy 195/65-14s while the vert will run 235/45-17s
P.S. i still want to drive ur car :)Comment
IWhile you will get more camber from H&R Sport springs, setting a bit less than normal toe will help with front tire wear. On the street you can go down to 1/16" total toe without adversely affecting stability.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, ALComment
wtf? you do not needs plates with h&r sports.Good to know. I made the mistake of trying to add up all the parts I will need to buy for the 'vert project, and the number made me want to crawl under the desk and cry. So if I can save $150 and not go with adjustable camber plates, I'm all for it. I don't have any on the coupe and it seems to be fine, but it's also riding on big floppy 195/65-14s while the vert will run 235/45-17s
Also, that tire size is way too tall for an e30. Even 235/40-17's are 1+ inches taller than stocksigpicComment
the front tire wear is not as big of an issue as the rear. Major camber going on. I rotate front to back with every oil change.Your signature picture has been removed since it contained the Photobucket "upgrade your account" image.
www.gecoils.com
My euro 316 project Transaction FeedbackComment
