Hi guys, I haven't been on these forums in quite some time; but now I am back in an e30. I am currently in the process of replacing quite a few parts, including bilsteins/h&r, SS brake lines, new rotors/pads, timing belt/water pump, bushings, and new tie rods and CAs. Pretty much everything has gone fairly smoothly so far, I was even able to get the center brake lines replaced without dropping the subframe thanks to a write up on this site. Anyway, I am currently trying to get the tie rods and CAs off but I cannot for the life of me get the damn locking plates pulled backwards on the tie rods, is there anything I can do about this, any tips? Is it possible to remove the tie rods without pulling back on the locking plates, I would assume not? Also, with the CAs, I am under the impression that it takes a 22mm wrench to get them unbolted, this looks like it will be annoying to get out, any tips on that as well? Thanks for any help guys!
Alex
Alex
