Originally posted by atomic
View Post
Ground Control Kit•Lame instructions
you need spacers in the struts otherwise the shocks will move up and down man...even with shortened struts....put the spacer on the top side and keep the shock from blowing or use bump stops but those are not for meNo more e30s for me.
88 black BMW OBDII 332is dedicated track [sold]
88 BMW OBDII bronzit 332is [RIP 03/08]
91 BMW 325i [sold]
86 Corolla 'Ae86' HB 20v trd [sold]
http://youtube.com/watch?v=pTj7Hn9v5Rs
c/o's
I never saw that link......thanks, good general info.
But.....
there is now way how I see in my current Koni SA /HR race set up to put the spacer on top.
Im not saying Slyder is wrong..but I cant wrap my head around it....
One would have that much less piston exposed to use on compression wave. It makes no sense to me.I love sitting down and just driving!
idk guys, the shocks i got from GC had kind of a long shaft so my springs separate a bit when i put the car on stands. so,
-putting spacers on the bottom give you more travel.
-^^but not really 'cuase once the car's back on the ground you'll have the same travel
-putting spacers on the top keeps your shocks from bottoming out.
-putting spacers on the top also keep the springs from separating as much form the shock/hatNo more e30s for me.
91 BMW 325i [sold]
And using bilstein sports with GC camber plates is a pita....Mtech1 v8 build thread - https://www.r3vlimited.com/board/sho...d.php?t=413205
i run the spacer on top, its impossible to bottom out the shock this way. doesnt mean you cant blow the shock, just that it cant bottom out. and when you are really low like me, not bottoming out is pretty important.
however, cutting/ shortening the strut housing is the best way to go with short body shocks, its just not easily done. i had a shop attempt to shorten a set of strut housings i had, and they were completely un-useable when they were done.
vorchlag plates FTW BTW.IG: @Baye30
Originally posted by E30Driv3R View PostYou might not have the Short Bodied konis?
I do.......or else the spacers would have caused major issues....no?
Im not trying to argue......but Id need some1 to show me this in person to get it. Im a bit thick.
I understand the shock may not bottom out.....but it would seem youd lose travel as well.
Sorry for not understanding. Im out on this one.Last edited by JRKOUPE; 02-08-2008, 11:11 AM.I love sitting down and just driving!
Originally posted by JoelRKaplan View PostI do.......or else the spacers would have caused major issues....no?
You really can put the spacer in the top or bottom depending how low you are going. I trust C3Motorsport more then Ground Control due to past issues with GC.
If you want to go low with either Bilsteins or Koni... Put them on top of the insert.
If you Dont wanna go extremley low put them where you want, i put them on the top since i am LOW.
If you put them on top with Bilsteins and go low you will be pretty much riding on the internal bumpstops.
i have a PDF file of the C3Motorsport instructions (Install is the exact same way) i can email to you if you want.
If you think about it with the spacer ontop you may have excess travel, i never checked, but since i am not using bumpstops i like that i have that little extra room.
The easiest way to not worry about this it just cut the extra part of the strut off, again it is not the easiest route, but probably the best.Last edited by E30Driv3R; 02-08-2008, 05:00 PM.Dan Zickel
1995 M3, 1991 318iS, 1987 325iS
Someone please correct me, as I too am now curious.
Originally posted by evo3 View PostFrom what I understand.. Less is exposed, but just because you can't see it (as it's covered by the spacer), it still has active travel. Whereas, if you put the spacer on the bottom, it pushes the shock higher, thus compressing it more- which would give you less travel, no?
....how can it have active travel?..the spacer will stop the travel once its contacted during compression..no?
W/ the spacer on the bottom.......the shock will act like a regular length shock in a non modified housing.
In a very much lowered car.....Id cut the housing an inch or so...and cut the spacer and inch or so...and still put in on the bottomI love sitting down and just driving!
