Collar nut hell (changing cartridges).. any advice?
  • houstonh
    • Aug 2007
    • 293
    So.. I got some extra front suspension to play with. Got the springs off.. went to pop out the cartridges. My pipe wrench didnt fit around it... so I proceeded to use a 1/2 extension and a Five pound sledge. The top of the collar nut came off. Fun stuff.
    Any advice or tricks/experiences with this issue. I am kicking myself for not just buying a bigger pipe wrench.
    I got bilstein sports going in...
  • Teaguer
    • Sep 2004
    • 6167
    If there is nothing left for a bigger pipe wrench to grab onto I would grind/drill a notch into what is left and then try to tap that out .
    Usually one the gland nut breaks free it is pretty easy going from there .
    • browntown
      • Jun 2004
      • 3524
      I don't know anything about changing a collar nut, but found this resource which should help. Use an air hammer with chisel bit and destroy it:
      • houstonh
        • Aug 2007
        • 293
        looks like I need to get an air chisel. I have sliced, diced it, all to no avail. I can now get my vice grips on it, but the fugger doesnt budge... the copper just distorts.
        nothing is easy :)
        • FredK
          • 14763
          I just cut the top off then tapped out the rest of the stub with a chisel. Mine were rusted solid to the strut housing.
          • delphini
            • Apr 2006
            • 680
            I used the claw end of a hammer to grip , and use another hammer to turn that to get mine off of my 87.
            :pimp:
              • 37833
              An air hammer is usually the tool of choice for this.
              Grover Beach, California
              BimmerHeads.com
              • golde30
                • 11464
                lotsa PBblaster, let it simmer for while, go back at it.
                IG: @Baye30
                • houstonh
                  • Aug 2007
                  • 293
                  got it with an air hammer. SOB!
                  • houstonh
                    • Aug 2007
                    • 293
                    ugly
                    1
                    2
                    • peter_x
                      • 24
                      A shop did one for me for $10. They had this socket (or similar):
                      http://www.samstagsales.com/bmwtools.htm (Go down to where it says "strut pin wrench"
                      • Tarn
                        • Sep 2006
                        • 212
                        Big vice and a 3' pipe wrench will get them off.
