M3 springs? dropping just the front...
  • Snoboarder156
    • Oct 2007
    • 83
    Ok, i need some help/advise... I have my first E30ic and i want to drop just the front about 1" to 1 1/2"... do the OE springs that came on the M3's provide a drop? is there any company that would sell just the front spings, not just the entire kit? I really like the ride height that the rear has... i am just wanting to close in the large gap up front and improve the handling a bit...
  • e30_kid89
    • Apr 2006
    • 489
    It may look like it now, but when you drop the front the rear will look higher and funny, then you will want to drop the rear as well. Also it isn't really good mixing springs & spring rates.
      From the factory an E30 has almost perfect front to rear weight balance. If you drop only the front you'll be shifting weight to the front wheels and the result will be a pretty tail happy car. If you are going to play with the springs, do it right with a matched set.
      • redhatpat
        • Aug 2005
        • 656
        I think the M3 springs will only drop the front about 1/2". You might want to get the H&R sport springs. That will give you a 1 1/2" drop.
        • Wishno87
          • 6025
          i just put some M3 springs on my cabrio about a month ago and it was about 1/2". its noticeably lower and stiffer but not a huge change. it did give it some rake though because the M20 is heaver than the S14
          • Snoboarder156
            • Oct 2007
            • 83
            Originally posted by jlevie
            +10...
            That make no sense what so ever! first by dropping the front 1" it will not shift the weight enough to make any difference in the way it is "balanced" and 2nd, every single "kit" on the market drops the front down lower than the rear! so ultimately what your saying is that every person that has put a lowering kit on there E30 has messed up the balance of there car...
            • Snoboarder156
              • Oct 2007
              • 83
              Thanks! i'm glad to hear from someone who has already done it to theirs!:D
              • delphini
                • Apr 2006
                • 680
                drop can be addictive...... the rear you WILL eventually want lower
                cabbies just look so much better dropped!!!
                :pimp:
                • gearheadE30
                  • Jun 2007
                  • 3734
                  Believe it or not, 1" actually is enough, especially when the front springs are stiffer than the back. That car would be downright scary at speed in the rain. i've ridden in one with this setup, definitely do the front and rear.
                  Project M42 Turbo
                  • Snoboarder156
                    • Oct 2007
                    • 83
                    Sorry to bring back a dead thread but I thought this was pretty amusing...
                    So just last week I got the H&R Sport springs and installed them. Now here is the amusing part. My car has 235K miles on the springs, so when I installed the rear HR springs it actually lifted the back end up 1/2"...
                    So the stance is perfect and I'm loving the ride!
                    • themitchster359
                      • 654
                      hahahahaha, thats pretty funny...oh old ass e30's
                      89 Alpine White e30 325i
                      • E30_fiend
                        • Apr 2006
                        • 7348
                        If your car actually did lift in the rear then you need to check your trailing arm bushings. No matter how many miles you have on your car, when installing lowering springs, there should be absolutely no lift. Only drop.
                        I would definitely check out your rear suspension.
                        Taylor
