how to raise a suspension?
  • Chris E30 Cab
    • 866
    I have some VERY low SPAX springs/dampers on my new turbo E30, and was wondering if there was a way to raise the ride height. Obviously taller spring pads can be used in the rear, but what about the front? Any spring pads there? Or could I have someone fab up some type of nylon or other substance spacers?
    I'm having a hard time finding IE stg 3 springs right now so I thought this may be a solution.
    Thanks!
  • Jordan
    • 12916
    thicker spring pads should be available for the front as well, they are present on the top and bottom.
    https://mtechniqueabs.com/
      I know that a thicker upper spring pad is available for the front. Dunno if there's also a thicker lower pad. I used the thicker upper pad on my Spec E30 to reduce the gap that happens with H&R race springs when the wheels are off the ground and to shift a bit of weight onto the rear wheels. I'd say those pads lifted the front by about 8mm.
      If you can't find IE Stage 3 springs, H&R Race springs are nearly equivalent.
      • StereoInstaller1
        GAS
        • 22679
        Camber adjustment plates will raise the front too.
        Closing SOON!
        Thanks for 10 years of fun!
        • Chris E30 Cab
          • 866
          Thanks fellas...I may just grab some H&R race springs and call it a day. I don't think the spring pads will raise it enough, and I've got to get this thing driveable on the street.
          jlevie....any pics of your car with the H&R race setup? I saw on TMS that they lower around 1.6 Front & 1.5 Rear....this is almost the same as the Eibach's lowered my cab in the pic below, which is still very streetable, but the H&R Race's will be far better for the track & autox of course.
          • atomic
            • Jun 2007
            • 5691
            See my sig below for H & R race spring setup on 215/40-17 tires. Very streetable
            • Chris E30 Cab
              • 866
              Thanks Atomic.....what size wheels tires are you running in that pic? also what offset?
              I'm considering some Sportmax's in 16x8 ET15 so i can fit some wide rubber in the rear but with the ET15 I'm sure I'll have fender lip issues with 225 to 245's mounted. I'm diggin how inexpensive and light the Sportmax rim is, and imo they aren't too bad lookin overall, sans the multi-fit lug holes. Anyhow, future plans are to bring my staggered 16" 3pc Hartge setup over from SG so the tires will be interchangeable.
              • atomic
                • Jun 2007
                • 5691
                No problem at all...
                Those wheels are 17x7 et25 with 215/40-17 BFG KDW-II's on H & R Race with koni top adjustables
                EDIT --- The wheels and tires on my car are for sale as well. Going 5 lug now ... roughly 500 miles on the set
                • Chris E30 Cab
                  • 866
                  thanks for the extra pics....it def helps. I gotta stick w/ 16's though so good luck with the sale.
                  • rwh11385
                    lance_entities
                    • 18403
                    Dave's on H&R sport
                    Eibach Race with spring pads in place
                    16X7 215/45/16
                    Hope you are enjoying being back in the US.
                    • Chris E30 Cab
                      • 866
                      Thanks for the pics man, H&R Race FTW!
                      Ya it's good to be back in the US after so long overseas, but getting this 325i turbo sorted is killin my wallet!! I just wish I could bring the cab over.
                      • Justin B
                        Sikky Nar Nar
                        • Mar 2005
                        • 4273
                        Originally posted by lance_entities
                        Dave's on H&R sport
                        Despite what he said in the suspension thread, those are actually H&R Race springs on his cabby when he still had it. I just cleared that up with him finally myself. He has also since then noted otherwise that they are in fact race's. I saw that pic and what he thought the springs were at the time and bought sports specific to the vert.
                        FWIW, this is mine, yesterday. On H&R vert sport springs. Nowheres near as low.... =( Same size tires too, stockers.
