Any good write-ups on Camber plates.. I'm debating.
  • houstonh
    • Aug 2007
    • 293
    Pardon the punctuation in the title.
    I want some camber plates with versatility. They need to be able to be run with coilovers or with standard style springs.
    I am wanting to hear opinions on Ground Control, Vorshlag, and IE... and others. I have read a lot on the Vorshlag, but they are somewhat cost prohibitive.
    Can the IE or GC kits be easily switched to run coilovers/standard springs?
    Can anyone tell me any shitty stories about either?
  • Teaguer
    • Sep 2004
    • 6167
    Houston , the only thing you need to know about when it comes to camber plates is Vorshlag .
    If you've done some reading then you know they are the best period .
    You can run them with stock style coils now and with coil-overs later by changing the upper hat .
    If cost is keeping you from them maybe I can get you a slightly better deal as Terry and Brian can cut deals on their older stock .
    Same stuff just doesn't have the newer etchings in them .
    • ddavidv
      • 344
      IE, not so great. Intended for stock type springs anyway.
      • PiercedE30
        • Apr 2005
        • 4220
        Vorshlag
        /thread
        My 2.9L Build!
        • xLibelle
          • Aug 2004
          • 2673
          does someone know the stack heights for these units?
          • Teaguer
            • Sep 2004
            • 6167
            The Vorshlag camber plates have the shortest stack height out there for a true camber plate .
            You can check out THIS for measuremants of the E36 set-up .
            The E30 will pretty much be the same .
            For $20 you can opt to go with a different upper perch bearing that is 5mm shorter .
            • JRKOUPE
              • Dec 2004
              • 3159
              camber plts
              A little late here
              but why would you say Vorshlags are better than GC?...........specifically
              • PiercedE30
                • Apr 2005
                • 4220
                Better design, easy to use, and better materials.
                My 2.9L Build!
                • Eric
                  • 5141
                  how is the design better?
                  to me it looks like the vorshlag will have the same problem as ground control.
                  the alen bolts for adjusting camber will make contact with the ID of the strut tower opening before the full range of camber adjustment is met.
                  Somebody should either make a new plate with the camber slides recessed, or make a 1/4 inch spacer to drop the plate below the below the strut. then you can set the camber, then set the caster.
                  INMO you are an idiot if your dumping the camber down at the track and moving it back when you leave. Set it once on a machine and leave it.
                  • JRKOUPE
                    • Dec 2004
                    • 3159
                    why not reduce neg camber on the ride home?...what if you are going 300 miles on tram lining roads w/ ruts etc.
                    neg 3.5 degrees driving home can be a bit annoying when you are exhausted from the day.
                    • Jean
                      • 18228
                      The GC (what i have on my car) seem to work just fine, and the material is fine too. The only problem I had with mine initially is during the install, the bilstein sport inserts don't have a long enough thread to mount them vs. the koni adjustable shocks and you gotta pay attention on how you install / tighten them. Other than that they work as designed, I've had them for just over a year now.
                      • kishg
                        • Sep 2006
                        • 2624
                        concur. i have GC with koni sa and no issues so far. about a year installed.
                        '12 F30 328i Sport Line
                        '91 SpecE30 #523
                        '00 Ford F-350 Dually Tow Vehicle
                        BMWCCA #360858 NASA #
                        128290
                        • CorvallisBMW
                          Long Schlong Longhammer
                          • 13039
                          Which of these have urethane mounts and which are solid? How's the ride with solid mounts?
                          • funcrew
                            • Jun 2007
                            • 1223
                            When I install IE stage 3 springs, how much negative camber will that produce, before any camber plate adjustment?
                            "If the sky were to fall tomorrow, the tall would die first."
                            -Dr. Paul Forrester
                            Do I LOOK like I need a psychological evaluation???
                            • PiercedE30
                              • Apr 2005
                              • 4220
                              JoelRKaplan: empty your message box.
                              My 2.9L Build!
