Rubber suspension???
  • thornado327i
    • Oct 2006
    • 501
    Came accross something like this:
    It's suppoesed to be "wrapped" around the spring - here's how:
    Guys who sell that (about 1,20USD each) claim that it makes the suspension stiffer and prevents the car from sitting too low when you have passengers on board or a full trunk of whatever.
    To me it sounds like a total garbage. But maybe someone has heard any proven opinions on those, or even better tried them on.
    Seems to me like another e-bay cheap stuff for "wish I had a cool car" freaks...
    What do you think?
  • alpinaclone
    • 820
    I've seen those in circle track catalogues, like Speedway Motors. They even sell them in diferent hardnesses to adjust spring rate. I can't comment on effectiveness though.
    Matt
    • Schneider325
      • May 2004
      • 3818
      Just sell whatever you have now and get stiffer springs.
      done
      • ldsbeaker
        • Aug 2004
        • 3098
        I would DD it for about a month, check it out. $1.20 a piece? Yeah, no problem.
        Slicktop City!
        • e34john
          • Apr 2006
          • 3599
          Seems like it would work to prevent things from getting too low under heavy loads, maybe I should try them because my tires rub sometimes.
          • gearheadE30
            • Jun 2007
            • 3734
            looks like a cheap alternative to a good suspension. I can see how it would help load capacity, but there is no way that rubber blocks will increase stiffness.
            Project M42 Turbo
            • DaveSmed
              • Apr 2007
              • 1407
              Just the ticket for your '84 Caprice with the sagging rear springs!
              -Dave
              2003 Lincoln Towncar | 1992 BMW 325iC | 1968 Cadillac Deville
              Need some help figuring out the ETM?
              • 1991 318is
                • Dec 2005
                • 786
                These are what NASCAR guys call spring rubbers. They have different hardnesses but are stiff urethane. They shorten the length of the spring and increase spring rate. Porsche has a nice setup on the racing 911's that uses a metal version that moves up and down on the threaded shock body above the main spring perch. Being metal they change the spring rate in a more direct manner than a urethane piece which has some flexibility. The main advantage in racing is you can soften a corner of the car with minimal effect on "wedge" or cross weight. NASCAR and the factory Porsche race cars use them and they sure aren't "wish I had a cool car" freaks...
                • thornado327i
                  • Oct 2006
                  • 501
                  Wow. You sure kept me waiting with your replies for a while ;)
                  Maybe I should try them. My springs are great when it comes to cornering, but whenever I have to transport something heavy, or have 3 passengers on board the car sits a bit too low, and my wheels rub a bit on bumps (very few roads without them out here).
                  As I stated above, I seriously doubt they will make my suspension work better (it's just some piece of rubber).
                  Just wondering - given you have a -35mm rear springs - do your cars get lower a lot under some load? My springs are Jamex (Dutch) and they are defi... definet... undoubtfully (yes!) not HRs, but the are being considered pretty good. Especially that we have a real flood of cheap "german" springs out here.
                  When it comes to Jamex springs - that's the only problem discovered so far - they get too low under some load. Other than that - they work great. So my question is - do HRs (for example) behave better under such conditions?
                  • e34john
                    • Apr 2006
                    • 3599
                    where did you see them? I will give it a try on the rear. hope it will allow me to carry passengers
                    • Eric
                      • 5142
                      this would be good to use in classes like spec E30 to corner balance a car....
                      • thornado327i
                        • Oct 2006
                        • 501
                        Polish ebay ;)
                        Or actually an equivalent of eBay - http://www.motoallego.pl
                        So far, I'm running 14" steelies with 185/65 rubber - no rubbing there. But when the winter ends, and my 16/9" are back on the car - I'll give those things a try.
                        • e34john
                          • Apr 2006
                          • 3599
                          Can't find them around here. All i see are rubber ones that cost about 50 dollars a set.
