e36 rack spacer
  • rccardude909
    • May 2007
    • 97
    e36 rack spacer
    I was wondering if there was a washer thats supposed to go under the rack that I missed. I'm using the AKG rack spacers and theres still maybe 1-2mm gap to prevent the rack from sitting tight inside of its mounting bracket on the subframe. Thanks
  • FredK
    • 14763
    You shouldn't need any washers.
    I used AKG rack spacers and there's really no play at all. Once you cinch things up with the two through bolts, there should be no more gap.
    • PiercedE30
      • Apr 2005
      • 4220
      I used 3 head bolt washers on each side. Fit perfect.
      My 2.9L Build!
