polyurethane VS rubber CABs?
    someone told me that polyurethane squeaks, cracks, and isn't necessary if the car isn't a track car.
    have i made a mistake in buying the powerflex centered front CABs?
    I have a stock 325e
    -Mike
    1985 325e
    mods:
    Powerflex CABs
    MOMO Corse Exhaust
    euro bumpers with BBS front spoiler
    e36 m3 shifter
    uuc clutch stop
    Dude, you'll be fine just install them. They will increase NVH a bit though.
      and NVH is..?
      i don't know.
      1985 325e
      mods:
      Powerflex CABs
      MOMO Corse Exhaust
      e36 m3 shifter
      uuc clutch stop
        Noise, Vibration, Harshness
          Ah. I see.
          Is it hard putting the CABs back onto the control arm?
          1985 325e
          mods:
          Powerflex CABs
          MOMO Corse Exhaust
          e36 m3 shifter
          uuc clutch stop
            Originally posted by mikejungle View Post
            Ah. I see.
            IIRC, the hard part is getting it back into the lollipop - usually its pressed in. getting the bushing/lollipop combo back onto the control is not too hard - just grease her up nice.
              ^what about pulling it off?
              1985 325e
              mods:
              Powerflex CABs
              MOMO Corse Exhaust
              e36 m3 shifter
              uuc clutch stop
                pulling both the bushing/lollipop off? just grab and pull - the bushing will most likely tear a bit. pull and twist back and forth till it comes off, hope you've been hitting the gym ;)
                getting the bushing out of the lollipop, easiest way is take them to a shop and have them pressed out and in. hard way is hack at the old ones to get them out, and be creative getting the new ones in without damaging them. most on here will suggest you get them pressed in at a shop. will take the shop 5 minutes.
                  hm, what about a big c-clamp and some wood boards for even pressure?
                  just a thought.
                  1985 325e
                  mods:
                  Powerflex CABs
                  MOMO Corse Exhaust
                  e36 m3 shifter
                  uuc clutch stop
                    It had better be a big ass c-clamp. Those CABs are in there pretty good.
                      I have a stock 325e
                      -Mike
                      Urethane is certainly not needed for street use but it's not a bad thing.
                      As for changing them....getting the old ones off will be the worst part. You can use a 2 or 3 jaw puller carefully and you will tear the bushing. Then the inner part/sleeve is left on the control arm. Again, you should be able to use the puller to get it off. Take the parts to a shop and have them press in the new bushings. They should go back on pretty easily.
                      Cheers.
                      Jack Money
                      http://www.Elephant Motorsports.com
                      >> AST 4100 for BMW E30 $1649 <<
                      AST Monotube Dampers and Coilover Kits - Full Service Dealer
                      Schroth Safety Products Distributor
                      BMW Replacement Parts - 24/7 Secure Online Ordering
