M3 Sway Bar Specs?
  • James Crivellone
    Head Janitor
    • 6304
    M3 Sway Bar Specs?
    Tonight I am picking up an M3 Instrument Cluster and an M3 Rear Sway Bar.
    Would the front bar be a good upgrade over my stock sway? or should I still go with the Cabrio Front Sway bar?
  • M-technik-3
    • 18946
    Apples and oranges. totally differant mounting points and the M3 bar is smaller but due to mounting points is better, but you need to get you strut tubes welded.
    • James Crivellone
      Head Janitor
      • 6304
      Ok, that is what I was unclear on, I knew the sway links themselves were different, but that was all.
      I guess I will still go with the Cabrio Front Sway with the M3 Links
      • Rob
        • 8166
        if you're doing the cabrio bar, dont bother with the different links
        BEERTECH
        • James Crivellone
          Head Janitor
          • 6304
          Really? I have heard of some good improvments with that upgrade?
          • Rob
            • 8166
            well, the M3 mounting point effectively makes the front sway bar perform like its actually larger diameter, hence the smaller diameter of the front M3 bar. If you do both a bigger diameter bar (Cabrio) and the m3 mounting point, the front sway bar will act even bigger. you dont want to upset the balance I dont think. Too large a front bar will promote understeer, which will suck.
            Therefore, If it were me, I'd either do M3 bars F&R with the M3 mounting point, or the cabrio front bar on the stock mounting point and the m3 rear bar. Honestly, I doubt many people will be able to tell a difference between the two setups, and the cabrio/m3 combo bolts up to an e30
            BEERTECH
            • M-technik-3
              • 18946
              Underster the reason why BMW does staggered wheel sizes nowadays. Promotes slowing for curves.
              • Mystikal
                Wheel Fitment Expert
                • 9602
                Rear bar upgrade only sounds like fun. How much do they go for on the market?
                • aaron_silva
                  • 1785
                  Picked mine up for $30.
                  Aaron
                  • Mystikal
                    • 9602
                    Sounds like a plan. Thanks.
                    • m42technic
                      • 1056
                      Aaron
                      Got mine fo free. :P
                      James Peacock
                      WWFSMD?
                      • rs4pro3
                        • 5808
                        I agree about the cabrio bar and the m3 links that is my setup right now and it understeers now where before with just the cabrio bar it was about perfect. I'm probally going to stick an 18mm front bar on and see how that feels. or go with a large rear bar as I just have the stock one.
                        85 325e 2.7 ITB'd stroker
                        • Mystikal
                          • 9602
                          Upgrading the front bar only was a rather interesting move in the first place. Why did you do it?
                          • Jordan
                            • 12913
                            Because Ely does everything bass ackwards.
                            https://mtechniqueabs.com/
                            • rs4pro3
                              • 5808
                              Yep exactly
                              It was perfect handeling with the 21mm cabrio bar alone. Now with the m3 endlinks the front stays perfectly flat but the rear body roll is noticable. It handles fine and any one who rides with me comments on how well the car sticks. But before with just the 21mm bar the car felt more neutral.
