What else do I need?
    I have new - TMS front and rear swaybars, TMS solid rear subframe mounts, Solid billet rear shock mounts, A camber kit, Beefed up front subframe (welded TMS) kit. Aluminum control arms, and new tie rods, I am planning on purchasing the http://www.purems.com/products/product.php?II=662 kit with adjustable koni's and vogtland springs. Is there anything else that I am missing, or should do when I install all this besides an alignment? Thanks
    Sway bar end links, and you should get the rear sway bar tab reinforcement weld on kit for your trailing arms. What "camber kit" did you buy?
    If you need brakes or brake lines, this is an opportune time.
      Might as well do your brakes and wheel bearings + trailing arm bushings. Weld an A frame bar to your trailing arm as long as your welding.
        lol, now thats a lil much.
          My subframe is already welded. Brakes are new, but i might do wheel bearings/axles while I am in there. I got a fully adjustable front camber kit (can't remember the name). I do have new trailing arms. Can you post a link to "rear sway bar tab reinforcement weld on kit for your trailing arms"? Thanks
