Cliffs : Insatalled c3 kit 500/850, I pushed the stop up all the way and put the zip tie at the bottom, ran an autox and was obviously bottoming out.
I recently installed coilovers with short koni SA's, I did not shorten my strut housings because I wanted to have about 6" frame clearance for some events. I took them out for the first time at an autox, adjusters were at nearly their highest settings, I have about 5.5" to the frame, still only a couple inches to the bump stop. This worried me so I used the zip ties on the strut shaft trick, pushed the bump stop up all the way, set the zip tie on the top nut and set off. When I got home I saw that the zip tie was pressed into the bottom of the bump stop, so obviously I was bottoming out. I drove about 2miles to the autocross, did my runs and drove back, no big jumps or potholes, just your normal stuff.
The c3 site says you may need to shorten your bump stops if you want to lower your car more, but at the highest settings I'm hitting it. So my question is, should I just shorten the bump stop (how much?) or is something wrong with my setup?
Pic before install.
Pic before install.
cing.com
