I just unpacked my IE sways in preparation for installing next week. Attached to the front adjustable endlinks is a triangular piece of metal that I wasn't 100% sure about. I am guessing that it needs to be welded to the control arm as a reinforcement?!? If this is so, do I need it welded on the top or bottom side of the control arm? Thanks.
IE Swaybar Install Question
As far as I know, no reinforcement of the front pickup points is required. The rear must have the pickup points reinforced. The triangles furnished will work, but the type that Turner sells work a lot better since they triangulate the load.The car makes it possible, but the driver makes it happen.
Jim Levie, Huntsville, AL -
Are you sure you aren't looking at the rears? The rear links have a triangular reinforcement that is welded to the mounting points.Aaron
Thats exactly what I did- I was looking at the rears. Wow I feel dumb, especially because somewhere in my head I KNEW that the rears mounts were weak. Thanks for helping in my moment of stupidity- I will do better next time not to turn this into another Honda-Tech forum ;)Comment
